Underwood shipment arrived
Started by dsonyay, May 10 2014 06:54:24 AM MDT
dsonyay
My order from Underwood arrived.  Can't wait to test.  The 5 boxes in the back are the Delta Elite loads.  I plan to run those through the Glock20 as a good break-in ammo instead of a couple hundred rounds of nukes.  The Delta loads have potent specs even if reduced just a tad for the non-supported barrels.
Shadow-- you get a sample of the Delta loads for your pull down database and test firing.
Osageid
Well have fun!! Underwood ammo is the only ammo I buy, I make the rest!
David, Looking good!  Hey bring one of the 180 XTP 1300 for a look see with the Delta Elite load.  Since Underwood has changed powders, it will be worth the look see... 8)
dsonyay
