what are your 1911 setups?
Started by 10mmfan, April 21 2014 10:18:21 AM MDT
10mmfan
I just joined and I am curious on the best setups you have found for 1911's I have a RIA 10mm with a 18 1/2# recoil spring and 26# mainspring and a flat firing pin stop. I also just bought a new kimber tle ii in 10mm currently stock.
Good set-up.  Same one I run in my Para P16/40/10mm.
10mmfan
How do the mags work on the para any modification needed?
10mmfan
Pics are always needed it is a RIA I swear.
Harleycolt
10mmfan
The grips are custom made water buffalo horn it took nearly six months to get them.
harleyhopper
I've tried several times to post a pic but keeps saying the file is too big. On my RIA, I've polished the sides of the slide,frame, trigger and hammer(in the white) and it looks like a Kimber Eclipse. Tthe Kimber will be my next one.
But on my Rock 10, a 20# recoil, 22# main spring and flag bottom firing pin stop have given me the best results. The brass piles up neatly and consistently about 15' away.
I do have a 22# Wolff recoil and 25# main springs to try but why change a good thing.
Wish I could post this iphone pic. Steve
10mmfan
Quote from: harleyhopper on April 29 2014 01:56:40 AM MDT
Which kimber are you looking at? My kimber isn't broken in yet but right now my groupings are much tighter with the RIA
10mmfan
Likely Wesnesday afternoon I will replace my mainspring, mainspring housing, recoil spring and firing pin stop on my kimber
harleyhopper
The Eclipse Custom in 10mm. Don't know why as the Rock is just fine. Thinking about going by the FFL today
harleyhopper
#11
Let's see if this works
Fixed by The Shadow
You needed the IMG code to make the picture work...
Osageid
I just received my Para Elite hunter, no mods
sstewart
I for one am interested in the springs, you guys are using.
Steve,
I know you changed your springs, but I can't find in one place what worked for you.
I too have a RIA 10mm that is back at Armscor getting a bent extractor issue looked at. Mine is stock and I expect mine to come back with stock springs. So ...
What are the setups for:
mainspring
recoil spring
other important (non cosmetic) changes.
(I like the pretty stuff too, but I am trying to get a handle on the operating stuff.)
