9x25Dillon Factory/Commercial Ammo Pull-Downs
Started by The_Shadow, April 20 2014 09:29:27 AM MDT
Cartridge is from Ammo Manufacture: Underwood 9x25Dillon Speer 125gr TMJ
Ballistics Information: 9x25 Dillon
Muzzle Velocity: 1700 fps
Muzzle Energy: 802 ft. lbs
Brass Make/Headstamp: Star Line – Brass 10mm headstamp
Bullet Make/Weight/Construction/Info; Length 0.5400"/Dia. 0.3555": Speer 125gr TMJ
actual weight 125.4 grains      crimp line 0.3540"
C.O.A.L.: 4 @ 1.2725" & 1@ 1.2580"
Primer: Brass color
Case: Diameter 0.4215" Crimp Diameter 0.3770" Length 0.9885"
Powder Description/Positive ID/Type/Charge Weight: IMR800X 11.0 grains
#1
Cartridge is from Ammo Manufacture: Double Tap Speer 90gr Gold Dot HP
Muzzle Velocity: 2100 fps 6"
Muzzle Energy: 881 ft. lbs
Brass Make/Headstamp: Double Tap – Brass 9x25 headstamp
Bullet Make/Weight/Construction/Info; Length 0.4460"/Dia. 0.3555": Speer 90gr Gold Dot HP
HP depth 0.2170" / HP dia 0.1420" (tapered) / Mouth 0.2420"
Actual weight  91.2 - 9.10 grains      crimp line 0.3485"  (concaved base)
C.O.A.L.: 1.2550"
Primer: Nickel color
Case: Diameter 0.4215" Crimp Diameter 0.3745" Length 0.9875"
Powder Description/Positive ID/Type/Charge Weight: LongShot 12.2 grains
Tested Velocity: 1940 fps – 1855 fps S&W 1006 5" Bar-Sto Barrel
#2
Cartridge is from Ammo Manufacture: Double Tap Speer 115gr Gold Dot HP
Muzzle Velocity: 1800 fps 6"
Muzzle Energy: 827 ft. lbs
Bullet Make/Weight/Construction/Info; Length 0.5260"/Dia. 0.3555": Speer 115gr Gold Dot HP
HP depth 0.1370" / HP dia 0.1425" (tapered) / Mouth 0.2410"
Actual weight  115.6 grains      crimp line 0.3485"  (concaved base)
C.O.A.L.: 1.2550"
Case: Diameter 0.4215" Crimp Diameter 0.3765" Length 0.9875"
Powder Description/Positive ID/Type/Charge Weight: LongShot 10.6 grains
Tested Velocity: 1575 fps – 1610 fps S&W 1006 5" Bar-Sto Barrel
#3
Cartridge is from Ammo Manufacture: Double Tap Speer 125gr Gold Dot HP
Muzzle Velocity: 1695 fps 6"
Muzzle Energy: 797 ft. lbs
Bullet Make/Weight/Construction/Info; Length 0.5500"/Dia. 0.3555": Speer 125gr Gold Dot HP
HP depth 0.1310" / HP dia 0.1600" (tapered) / Mouth 0.2585"
Actual weight  125.2 grains      crimp line 0.3500"  (concaved base)
C.O.A.L.: 1.2555"
Case: Diameter 0.4215" Crimp Diameter 0.3765" Length 0.9850"
Powder Description/Positive ID/Type/Charge Weight: LongShot 10.0 grains
Tested Velocity: 1525 fps – 1475 fps S&W 1006 5" Bar-Sto Barrel
The Underwood has been out of stock for a while. I almost bought a conversion barrel for it..
Many people who get into the 9x25 are being left out by commercial loaders, being a handloader, I just looked for something different.  When I started into this caliber, it was with my S&W1006 with a Bar-Sto 5" barrel, which I paid too much for and still had to fit it to the gun and have the chamber finish reamed, to make it work correctly.  It was a fun project that taught me a few things.
The LWD barrels for the Glocks were drop-in and the chambers were almost as tight as a case gauge.  The 3.78" for the G-29 works but velocity falls short but the 6" barrel for the G-20 brings good things to life velocity wise.  ;D
The Dillon Dies are expensive (dual carbide sections for 10mm and 9mm) but I found a guy getting out of the game and got a great deal on those dies to get me up and running.  I did buy some loaded cartridges (the ones I did the pull-downs from) from Mike McNett when I bought the Bar-Sto barrel and then purchased a few brass from him too.  Always looking for a deal on the used 9x25 brass, but the Dillon dies will make take the 10mm brass and shape it properly.
I have developed some good loads with other powders and still testing other newer powders from time to time.  I'm wanting to test CFE Pistol, AutoComp and BE-86 to see how it performs.  To me it is all about the learning experience! 8)
mag360
since for many people the "holy grail" of handgun rounds is the 125gr 357 magnum and given the performance I've seen from it in tests in both the 357 sig HST bullet and gold dot in both 357 sig and 357 magnum, this dillon has got to take that to new heights.
a 1600fps gold dot or hst would be incredible assuming they stay tightly expanded in the .55" range! or the special barnes 125gr 357 sig all copper, the 9x25 dillon has ample case capacity to send that one to the moon as well.  such an exciting cartridge, wish I was a handloader. Will have to live vicariously through you!
Yeah....I wish there were more factory offerings for the 9x25. Since I don't handload it doesn't make sense for me right now.
msjayhawk
Nice breakdown. Great info and you posted everything I could think of. Keep up the good work.
West Coast, Mississippi.
Osageid
very nice Shadow.  What is great is the fact I am on many other forums and this site is always referenced for its wonderful ammo pull downs ! Great job!
#11
Cartridge is from Ammo Manufacture: Underwood **MG 125gr TMJ (supplied by IC 8/2018)
Brass Make/Headstamp: Underwood – Brass 10mm headstamp
Bullet Make/Weight/Construction/Info; Length 0.5240"/Dia. 0.3540": Bronze 125gr TMJ
Actual weight 125.0 / 125.2 grains   exposed lead base   crimp line 0.3535"
C.O.A.L.: 1.2550" – 1.2550"
Case: Diameter 0.4215" Crimp Diameter 0.3770" Length 0.9885"/0.9880"
Powder Description/Positive ID/Type/Charge Weight: Longshot 10.8 / 10.6 grains
** maybe Montana Gold Bullet
Cartridge is from Ammo Manufacture: Underwood 9x25 124gr Hornady XTP (supplied by IC 8/2018)
Muzzle Energy: 796 ft. lbs
Bullet Make/Weight/Construction/Info; Length 0.5755"/Dia. 0.3545": Hornady 124gr XTP
Actual weight 124.2 / 125.2 grains   flat base   crimp line 0.3545"
C.O.A.L.: 1.2550" – 1.2560"
Case: Diameter 0.4215" Crimp Diameter 0.3770" Length 0.9865"/0.9880"
Powder Description/Positive ID/Type/Charge Weight: MAJOR PISTOL 14.4 / 14.4 grains *
* SHOOTERS WORLD RELOADING PROPELLANTS MAJOR PISTOL / LOVEX D037-01
Cartridge is from Ammo Manufacture: Underwood 9x25 Lehigh 90gr Xtreme Defender (supplied by IC 8/2018)
Muzzle Velocity: 2000 fps
Muzzle Energy: 800 ft. lbs
Brass Make/Headstamp: Underwood – Nickel 10mm headstamp
Bullet Make/Weight/Construction/Info; Length 0.5795"/Dia. 0.3540": Lehigh Defense 90gr XD
Actual weight 90.0 grains Soild Copper 0.2150" point to point /0.1100" inside cross/0.3310" length of flute/0.3510" cannelure line 0.1615" from base/0.0570" concave base/crimp line 0.3540"
C.O.A.L.: 1.2510"
Case: Diameter 0.4220" Crimp Diameter 0.3780" Length 0.9875"
Powder Description/Positive ID/Type/Charge Weight: LongShot 13.6 grains
QuoteThe Xtreme Defender is based on the popular Xtreme Penetrator product line. The XD ammunition has an optimized nose flute, total weight, and velocity to achieve a penetration depth up to 18 inches* with a permanent wound cavity (PWC) that is just simply enormous; no other expanding hollow point comes close to achieving anywhere near this diameter and volume. Not only is the PWC over 100% larger than any other expanding bullet, expansion is achieved despite being shot through barriers. The solid copper body ensures that wallboard, sheet metal, and automotive glass will have no effect on the Permanent Wound Channel.
*Falling within FBI guidelines
This round offers:
•   A permanent wound cavity (PWC)that is 2 times greater than any expanding bullet
•   Reduced recoil.
•   CNC machined from solid copper to overcome barriers to penetration
•   Radial flutes that force the hydraulic energy inward to build pressure
•   Minimal surface area to increase the force at the point of contact and sharp cutting edges that defeat barriers
As with all of Underwood Ammo™ rounds, we utilize flash suppressed powder so that your vision will not be compromised if it becomes necessary to use your firearm in low light.
While taking advantage of our state of the art testing equipment, this high performance ammunition is field tested using popular, real firearms that our customers are most likely to own out in the real world with all the elements you would experience. If for some reason Underwood Ammunition fails to meet performance expectations, we stand by our product 100% and will make sure the customer is satisfied with every purchase.
This ammunition is new production, non-corrosive, in boxer primed, reloadable brass cases.
