Granite Ammunition 10mm
Started by mt10mm, March 17 2014 05:15:08 PM MDT
mt10mm
mt10mm
It's because of being lead. I shot it through a factory glock barrel with no problems.
Yeah...when I get some hardcast from BB or UW, I will shoot it through my stock barrel if I don't have an aftermarket barrel by that time.
Dave84
A little is ok. I just wouldn't put a steady diet through a stock barrel though. Test reliability and then carry when you are camping or hiking. I wouldn't worry about getting an aftermarket barrel unless you're going for a six inch. Stay away from stormlake if you are. I could never get underwood to feed in it which is pretty much the point in shooting hot 10mm ;D
  I had two rounds and one wouldn't go bang.
EAA Elited Limited 1108 FPS/ 545 LBS
mt10mm
Quote from: Intercooler on December 14 2014 01:20:51 PM MST
Thats not good...  I have shot up all i had on hand and bought some UW TMJ about a mth ago. I didnt like the inconsistency in the charge.
#22
MT10mm, The 200gr HC's are not an issue he's going to send it back and I'll make them go bang for him...more than likely the primers may have taken a beating while pulling them down. (it can happen, but I think this are the first for me)
Here is the link to that pull down, http://10mm-firearms.com/factory-10mm-ammo-pull-downs/granite-ammunition-inc-200gr-hard-cast-gas-check-pull-down/
BTW the 200gr Hornady XTP's with 9.2gr's Blue Dot, http://10mm-firearms.com/factory-10mm-ammo-pull-downs/granite-ammunition-inc-200gr-hornady-xtp-pull-down/
I sent those also to IC and this were the results he had.
EAA Elite Limited 4.75" 1209, 1215. Average = 1212 FPS/ 652 LBS
One Granite HC and one #9 14.2gr's were the only non-firing rounds.
Quote from: Intercooler on December 15 2014 01:59:19 PM MST
Yea, It could be that the kinetic pulling process loosened the priming mixture or the primer was bad to start with...good thing is you can send them back.  :D
I'll take them apart and put new primers in them this time around for another try... ::)
mt10mm
Thanks for the info.. I do have some of the granite xtp loads left though
