The Clubs! 800, 700, 600 LBS of energy
Started by Intercooler, July 13 2012 10:17:47 AM MDT
Quote from: Ascension on July 16 2012 09:31:39 PM MDT
What shocked me is that they don't recommended using their hotter stuff in the Colt Delta Elite?? After seeing that I guess that I can now scratch the Colt off my want list!
Yup, it left my want list too.  After some pics of insanely poor chamber support  in a Delta that Intercooler had posted I immediately felt the same.
Quote from: sqlbullet on July 17 2012 09:53:22 AM MDT
The Delta Elite is a great base gun.  If you have specific customizations you want, eg.  I want a Schuemann barrel with an Ed Brown beavertail and thumb safety, and a Guncraft trigger...Well you get the idea.  In this case a Delta Elite is a great choice becuase the frame and slide will definitly be to 1911 spec.  Most custom builders I know want a Springer or Colt base gun.  Many will accept Caspian frames too.  They do this because the know the dimensions will be to spec, which means just fitting parts.
If you don't have specific requirements, then a Dan Wesson of Kimber is a better gun since they have a ramped barrel already and good upgrades to many other parts.
How does Wilson Combat fit into the mix of being or not being to 1911 spec?
I don't know.  I would be shocked to find they aren't.  My information is from Steve at Mars Guns, as well as reading other gunsmiths comments either on their websites or in magazines.
I doubt many of them get a lot of requests to perform work on a Wilson as they are already quite custom.
I would not worry about it that much with a gun in that class.  Part of what you are paying for is the name that will stand behind the gun, and that you won't need to do anything to it.  If you have issues or want changes, contact Wilson.  Their gun, their problem if it is not quite to spec.
Added Thunderbird to the 600LB Club. If you can get past the brass color it pops and is accurate!
Quote from: sqlbullet on July 18 2012 10:22:50 AM MDT
Thanks.  Any idea how decent the Wilson Combat 10mm chambers are for case support?  Good for full-house loads?
Last I checked they were ramped barrel, full case head support in 9mm, 38 super, 40 S&W and 10mm.  The 45 ACP was the traditional style.
Quote from: sqlbullet on July 19 2012 03:04:20 PM MDT
Does it simply not matter so much with a 45 being a lower pressure cartridge, or is it a more of "who knows" kind of thing?
Quote from: REDLINE on July 27 2012 11:11:09 PM MDT
If for no other reason (21K PSI), it's enough.  But, who knows?
Our first factory ammo member to the 600LB Club added. Winchester 175gr. Silvertips!
What were the numbers from the Winchester SilverTips... ???
Ted Nugent (Pearce Ammo) barely made it in.
Armscor is out of the 600LB Club. BVAC doing the loading and it's all backed down now.
Quote from: Intercooler on August 23 2012 11:24:48 AM MDT
Sad, along with being an embarrassment to say the least.
