10mm lever action and Sub-2000
Started by Raggedyman, January 13 2014 08:33:35 AM MST
Smee78
"Otherwise, it would seem to be less accurate than the other 10mm carbines available." What other 10mm carbines are there? I only know of the MP5 & Thompsons, what others are there I would like one that is a little cheaper :)
Smee78
We know exactly where one cow with Mad-cow-disease is located among the millions and millions of cows in America, but we haven't got a clue as to where thousands of illegal immigrants and terrorists are located.
Maybe we should put the Department of Agriculture in charge of immigration.
I think Oly arms makes an AR upper in 10mm.  They used to anyway.
AndyBir
I have a Marlin in 10mm Magnum that I had converted in 1995 from a .357 as the cartridge length an base
diameter are the same so only a barrel change is needed and at the time I had a S&W 610 done also but I lost that in 1997 when the British Government banned them. I also have a .41 Marlin that I bought a few years earlier than the 10mm, it was a good few years old when I got it but it still shoots very well.
rw
Quote from: sqlbullet on May 22 2014 08:15:32 AM MDT
They still do, midway had some a few weeks ago. They sold out quick
gandog56
Does it have to be a lever action? I still like the Mechtech conversions to make your 10mm Glock or 1911 into a carbine. It would use the frame and magazines, and you still have a pistol for the caliber.
Harleycolt
Quote from: AndyBir on July 05 2014 01:51:30 PM MDT
Dp you remember who did the marlin conversion?  A 10mm Magnum lever gun would be ideal to keep in the truck when out and about in the country? Pictures please!
MacEntyre
diameter are the same so only a barrel change is needed ...
I must live under a rock... never thought to compare 357 to 10mm. If I can find an inexpensive used Rossi 92 357 magnum, I'm going to make one myself!
- MacEntyre
Per Ardua, Infensus, Sine Politico, Haec manus inimica tyrannis
