Gelatin test results
Interesting load the 300Blackout is!   8)
Looked like that petal was visible in the video coming out the side.
Thanks!
Raggedyman
Yeah, you can clearly see it bounce off the table. I probably should have added some text pointing it out.
Interesting that it did that well...but I don't trust them! :-\
Raggedyman
It would be cool if they just made a low cost practice round.
Raggedyman
#231
#234
They busted the HP off as pieces and the core delivered a deep penetration.
Yes it is possible it was loaded with 16.2 grains Blue Dot   seeing You got 1319...
Lyman Devastators cast HP 255 grains Gas Checked
260 gr Lyman Devastator HPGC 0.431"
CCI 350 primer
COAL seated in cannelure 1.692"
Velocity 1370 fps 8 3/8" BBL
Energy 1083 ft/lb
Intercooler Tested those with the Ruger Redhawk 7.5" barrel 255gr Cast 22.4gr's 1246, 1262, 1260, 1250, 1301, 1270. Average = 1264.83 FPS/ 905 LBS
The alloy is straight Wheel Weight probably too hard...I can adjust the alloy
Captain_Witness
Question for you guys.. wondering what the terminal effect would be if the Devastator type bullet was externally powdercoated? Have a new, complete HF powdercoat set with powder and thought it might tame leading issues in the magnum calibers
Daily primary CCW: EAA Witness Elite Match 10MM
#236
Pull-Down was Dec.19, 2015
The Shadow added info...
Wolfie
I will pass on that Ruger ammo to.
Rojo27
#239
A new one from TNOUTDOORS9:
https://www.full30.com/video/455b7125df48f959ae023f3d31652449
TNOUTDOORS9 & RAGGEDYMAN both back testing ammo.....
