Gelatin test results
Did you ever look to see what DT was using in the 223 with the 77gr?   ???
Raggedyman
I can't. It's from a member at another site.
Rojo27
Thanks for sharing.
Sure reinforces Barnes TSX projectile reputation for deep penetration.  14" of ballistics gel, then another gallon of water...  Little surprised it didn't go into 2nd jug of water.
This would be excellent choice to hunt with imho but wouldn't be on my short list for a home defense.
Based on 7.62x39 testing you've shared so far; for home defense options I've been most impressed with:
Federal Fusion
Winchester PDX1
Hornady z-max
Raggedyman
I agree. I actually expected the bullet to stop in the first block, though. I think if it hadn't managed to shear off two petals, it would have. Another 50 yards out and the velocity might have been low enough to keep it together and have less penetration. That was what really surprised me. I wouldn't have expected a TSX to shed petals.
Rojo27
I kinda suspect the petal shearing was caused at or in the plastic gallon water jug.
TNOUTDOORS9 ran a similar test a year or more ago in 223 firing the 55 grain Barnes TSX.  His test results were very similar to yours, right down to petal shearing which he seemed to indicate occurred at or in the water jugs (if recollection serves).
Raggedyman
That could certainly be the case for the one you see st the end of the video but the other was left around 2/3 through the block.
#129
Looks like that 9mm 147 G-2 is a FLOP!  ???
Cor-Bon DPX interesting just like the Barnes TAC-XP, they are open and twisting till the fold the petals back.
Raggedyman
Raggedyman
#131
Fiocchi 147 gr XTP fired from G22 with Lone Wolf 9mm conversion barrel through four layers of denim into calibrated 10% gelatin.
BB: 592.8 fps, 3.6"
Impact velocity: 957.1 fps
Penetration: 14" of gel, one 6" water jug
Retained weight: 147.0 gr
Max expansion: 0.460"
Min expansion: 0.365"
I have changed up my format quite a lot over the last few videos and I'm interested to hear what elements you like best. Which camera angles and segments are most entertaining or useful to you? What should I change and what should I keep the same?
Repaired the Youtube link  8)
Amazed at the penetration from those...Thanks for the Jello test video!
Raggedyman
Thank you. Thought I got it right.
Raggedyman
7.62x39mm Sellier & Bellot 123 gr jacketed soft point fired from WASR-10/63 into calibrated 10% gelatin. This ammunition is brass cased and boxer primed with a heavy crimp on the case mouth. The projectile measures 0.311"
BB: 592.8 fps, 3.6"
Impact velocity: 2,438 fps
Penetration: 14" of gelatin, 6" of water jug
Retained weight: 81.5 gr
Max expansion: 0.608"
Min expansion: 0.475"
