Littlestone Ammo testing 155gr XTP, 155gr XPB, 165gr GD, 180gr GD, 180gr Sierra
Started by Intercooler, October 10 2013 05:10:31 PM MDT
IC, writes
Quote155gr Barnes 1151, 1157, 1143, 1145. Average = 1149 FPS/ 454 LBS
Which 155 Barnes bullet...was it the TAC-XP? ???
Was this ammo from Barnes or the Buffalo Bore loaded with Barnes bullets?  ???
This is Littlestone's 1200 FPS load where they use the Barnes bullet:
http://www.littlestonesrus.com/10mm-Auto-155-Grain-Barnes-XPB-Solid-Copper-Hollow-Point-Box-of-20_p_5207.html
Seems weak given Buffalo Bore is 1400+. I would like to see what both do in gel as a comparison.
OK It's a Littlestone's product with Barnes 155 TAC-XP... they were close to the marked velocity... 8)
   I had a few left to generate Hunter data today.
155 Barnes EAA Hunter 6" 1192, 1182, 1186. Average = 1186.66 FPS/ 485 LBS
155 XTP EAA Hunter 6" 1575, 1545, 1560, 1565. Average = 1561.25 FPS/ 839 LBS
165 Gold Dot EAA Hunter 6" 1441, 1422, 1454, 1459, 1441. Average = 1443.4 FPS/ 763 LBS
180 Sierra EAA Hunter 6" 1265 FPS/ 640 LBS
180 Gold Dot EAA Hunter 6" 1380, 1370, 1388. Average = 1379.33 FPS/ 761 LBS
