what is the mosr devastating 10mm round
Started by krafcheck, September 23 2013 05:33:17 PM MDT
P33v3
Quote from: sgtbones on October 29 2013 08:05:43 PM MDT
In my G20 I use Underwood 180 gr Gold Dots  DE load 1240 fps in the  winter . The G29 165 gr Underwood Gold Dots.
Those are both good choices. I have always believed that the 10mm should be paired with 180gr and 200gr rounds. 165gr is a good choice for the shorter G29 as it gives it just a little more zip to aid expansion.
Mike_Fontenot
Quote from: P33v3 on October 30 2013 03:54:55 PM MDT
But it seems to me that when you are moving to a shorter barrel, you perhaps may have to choose whether to try to preserve penetration (which would argue for a heavier bullet in the shorter barrel) OR to preserve expansion (which would argue for a lighter bullet in the shorter barrel) ... I doubt that you can simultaneously preserve both, unless you use a cartridge with a higher muzzle energy in the shorter barrel.  That's my thinking, anyway.
P33v3
Quote from: Mike_Fontenot on October 30 2013 06:15:44 PM MDT
According to the Master Ammo Sheet in this forum the Underwood 165gr GDHP is 732 ft.lbs vs the Underwood 180gr GDHP is 670 ft.lbs both our of a EAA Witness 4.5 inch barrel. So the lighter one in this case it would give a little more zip. I'm guessing that you would still see adequate penetration of >12 inches even with the lighter bullet and higher velocity out of a G29.
sgtbones
Yeah I could use the 1300 fps UW'S for the g29.
