MechTech - Glock "Bolt Safety"
Started by DenStinett, September 16 2013 07:59:20 PM MDT
DenStinett
I've learned the easiest way to clean the CCU is to lock the Bolt open and work through the Ejection Port
Well, I have already had the Bolt Handle slip and the Bolt slam closed on me
So I figured I needed a way to hold the Bolt open and safe from slamming closed
A "Bolt Safety" of sorts
Well I took a piece of Heavy Wire and I came up with is little number:
It goes around the Bolt Handle and the Hook slips over the end of the Glock Frame
Not sure how the 1911 Set-up looks, I'm sure one could come-up with something similar for it
I hope this idea helps others
Necessity is the mother of invention!   8)
DenStinett
#2
Ok, so I made another Hook
This one's to use when the Receiver is removed from the CCU
Still not sure what it look like under your 1911 CCUs, but I'm sure you'll get the idea:
