Underwood ammo in new Dan Wesson?
Started by RZ--10, September 08 2013 04:52:29 PM MDT
Someone did all the ACTUAL tests, not what you read and it doesn't agree with your THEORY.
First, in modern technical parlance, a theory is not someones idea.  It is an idea that has withstood rigorous empirical testing. Please see definitions 1,2 and 3 of the word.
Second, I documented my theory with references to articles written by the guys who actually performed the tests.  In them they site the specific weights of the recoil and main springs they use, as well as the radius they placed on the leading edge of the flat bottom stop.  Further, they document the results of changing that radius and the application of the different radii in modern firearm design.
QuoteI believe that it was Ned Christiansen that experimented with it [10mm + FB FPS ] first...and it caught on
Quote.
I am open to learning something new.  If you have empirical data to share, please reference and share it.  I am not trying to bag on you at.  Just what you are saying goes against the data I have read about the subject.  Data that is well documented and has been derived from well-respected, independent sources.
We can disagree. If you don't up the hammer spring you have gained very little of what it's intended to do for you. That's what people actually using the setup have expressed. I agree with my own actual results.
Really...I would love to see the accounts first hand.  Do you have any links I could read?  I am NOT trolling you.
Google the 1911 boards and tons of hits will come up with user feedback. I have used one in my 1911 and all my Witness pistols. A call to Wilson about proper setup using one might give even better info.
