Pro Grade 165gr TMJ & 180 gr TMJ (plated round nose) Pull-Down
Started by The_Shadow, September 07 2013 12:01:24 PM MDT
Cartridge is from Ammo Manufacture: Pro Grade 165gr TMJ (plated round nose)
Muzzle Velocity: "?" fps
Muzzle Energy: "?" ft. lbs
Brass Make/Headstamp: Pro Grade - Brass
Bullet Make/Weight/Construction/Info; Length 0.5590"/Dia. 0.4005": 165gr TMJ plated
Actual weigh 165.4 grains  Crimp Diameter 0.3950"
MEPLAT  0.2500"
C.O.A.L.: 1.2535" / 1.2560"
Primer: Nickel color
Case: Diameter 0.4210" Crimp Diameter 0.4210" (med crimp)Length 0.9870"
Powder Description/Positive ID/Type/Charge Weight: ? HP-38 or 231 ?  6.6 grains
Based on more info and pictures that were sent I changed back to HP-38 or 231 for the powder ?
(powder contains very fine brown dust like rust or copper)(maybe from plated bullets)
Cartridge is from Ammo Manufacture: Pro Grade 180gr TMJ (plated round nose)
Bullet Make/Weight/Construction/Info; Length 0.6015"/Dia. 0.4000": 180gr TMJ
Actual weigh 180.0 grains  Crimp Diameter 0.3950"
MEPLAT  0.2500"
C.O.A.L.: 1.2520" / 1.2520"
Case: Diameter 0.4210" Crimp Diameter 0.4200" (med crimp)Length 0.9875"
Powder Description/Positive ID/Type/Charge Weight: ? WSF ?  4.6 grains
WSF 5.7 @ 950, ? 231 5.8 @ 1030 ?
(Small spherical balls mixed in)  Still studying this powder and charge weight ???
What were the numbers for these?  ???  I'm still looking over the powders and without any velocity data it makes finding a profile to tie them together.
 ??? Kind of what I though from the charge weights observed... :-[
