CORBON Hunter180 gr BCSP Pull-Down
Started by The_Shadow, August 13 2013 08:57:34 AM MDT
Cartridge is from Ammo Manufacture: CORBON Hunter 180 gr BCSP  (Supplied by ROME)
Muzzle Velocity: 1320 fps
Muzzle Energy:    696 ft. lbs
Bullet Make/Weight/Construction/Info; Length 0.6370"/Dia. 0.4000": 180gr. JSP
MEPLAT 0.2150"
Actual weight 180.0 grains   Crimp squeezed bullet to 0.3995"
C.O.A.L.: 1.2605"
Primer: Brass color
Case: Diameter 0.4210" Crimp Diameter 0.4205" (light) Length 0.9890"
Powder Description/Positive ID/Type/Charge ?? AA-5 or HS-7 ?? Weight: 9.3 grains (yes I know the scale shows 9.2 it was changing between .2 & .4)
I am really leaning toward AA#5 thinking it is the "NEWER Stuff" and the charge weight seems to fit better to velocity some have seen.
I had some and tested but never sent. Shot them up :-X
Yea, I reviewed the Choppinbloc Video of it, they didn't expand and traveled deep! http://www.youtube.com/watch?v=3wEAPXNAkxY
I wish there were some people closer to me that handloaded, so I could study more and different powders in person.
After more study I am leaning toward this being loaded with AA#5 powder. (It maybe something else???)  They say the Newer AA powders are a little more like flatten ball structure than the very round black stuff of years past???
The older stuff I have was made in Israel, the newer stuff is made for Western Powders... Ramshot / Accurate / Blackhorn209.  (Notice that Accurate Arms is now only Accurate)
#4
Cartridge is from Ammo Manufacture: CORBON Hunter180 gr BCSP (Intercooler)
Bullet Make/Weight/Construction/Info; Length 0.6305"/Dia. 0.4000": 180gr. BJSP
MEPLAT 0.2575"
Actual weight 179.8 grains   Crimp squeezed bullet to 0.3945"
C.O.A.L.: 1.2725" (long compared to the other from Rome)
Primer: Brass color
Case: Diameter 0.4210" Crimp Diameter 0.4195" (medium) Length 0.9890"
Powder Description/Positive ID/Type/Charge ?? AA-5 or HS-7 ?? Weight: 9.2 grains
This is a repeat this one is from Intercooler the first was from Rome
