Finally! I pick up the EAA Limited Pro today and then conversion time!
Started by Intercooler, July 17 2013 03:55:14 AM MDT
     Took about a week longer than it should because they said they had a hard time locating 10mm ammo ??? I should have just asked them before I left that day.
      Tonight I plan on putting the Dawson sight and Henning pieces on before hitting the range tomorrow. I will post up some before/after pictures and test the DA/SA pulls to see where it's at. While I am in the mode I will pull the other 10's too for comparison.
    Now if I could just get the other one that is sitting at 100 days out of jail  :o
Did a bunch of work last night but couldn't get on to post it.
Here is the cool black case which is the better combo type. I have seen many of the cheaper plastic ones lately!
Before
Five 10's or as I call it... .50  :D
Dawson fiber-optic front in place. I ruined the green pipe the first try :(
I had doubts it would come with a Polygonal barrel but you tell me. Is it? I kind of think so which would be great for comparisons to the Match!
  Trigger pulls:
EAA Limited Pro 13.5lbs/4lbs
EAA Match 2.25lbs
S&W 1006 12.75lbs/6lbs
Dan Wesson Razorback 3.25lbs
EAA Hunter 3.75lbs
d762nato
Nice looking piece Congrats, and Daaauum! you are a 10mm freak. That's a nice assortment of 10's you have.
I'm done in the 10mm caliber.  Only possibility would be a new model revolver or plastic gun.
Very nice Intercooler!  Great looking metal work and finish.  Nothing wrong being a 10mm freak!  :D I wouldn't know anything about that...LOL ;D  The bore looks to be Polygonal style.  The trigger may loosen up some with use, lube, etc.
May it serve you well for may years to come! 8)
Thanks. I'm going to try killing it tonight :o
Packed up a bunch of 10mm for it's first session! I agree it will loosen on the trigger if you look at the other two.
DenStinett
Very VERY nice
Quote from: Intercooler on July 18 2013 08:04:49 AM MDT
I'm still searching for that ultimate 10mm Carbine
And looking forward to CZ marketing their CZ97 in 10mm
I succeeded  :o Flawless for about 50 rounds and then something black went flying! Yup... 10mm knocked out another sight ???
   I had just got it sighted and was starting to pop some off. I really like this pistol! My plan is to put a divot for the set screw to bite into and put it back on with some Loctite. This will be the new ammo test gun when I go testing ammo. The SA trigger acts just like the Match and the DA trigger is much better than the 1006.
  It's a good thing I take at least two 10's with me when I go in case I break one  :o I shot the 1006 and Razorback (back in service) after this mishap. Saturday I am going again and want to do the Limited with the Polygonal barrel versus the Match to see if their is a boost in velocity.
I tried to drill a divot but no luck. That Chrome finish and metal is tough! So I basically filled the channel with red Loctite and inserted it pushing out the excess. After that I torqued down the set screw. Do you think the Loctite bond will hold it in there?
DenStinett
Quote from: Intercooler on July 18 2013 07:02:59 PM MDT
If the Red don't hold, try Loctite Black Max
It's holding my Delta Sight Pivot Pin in
http://www.brownells.com/gunsmith-tools-supplies/general-gunsmith-tools/thread-locking-liquids/black-max-adhesive-prod6139.aspx
I may have to give it a whirl if this don't work. Drilling seems to be out and I plan on running a ton in the morning. Thanks for the tip!
