Positive range report EAA Witness Compact
Started by Intercooler, June 28 2012 08:48:59 PM MDT
pacapcop, I was just reviewing the ones you sent for pull-down, I have yet gone to shoot them since I put them back together.   BTW-Good report! :D
pacapcop
Only around 100 rnds total thru compact, but very pleased considering the past. Good to know the 9mm/.40 heavy compact spring did it's job in the compact 10. That factory duel setup is horrible.
pacapcop
#33
I see they have it for the Compact 10mm.Might be awhile,$$$.Range yesterday, shot nickel 180 jhp xtp's from underwood.Compact mags seem to like the nickel.No hiccups with full mags.
   For your compact absolutely! I know I would and plan on contacting both vendors tomorrow. If one is open to me sending my cone guide-rod I would like to see if they can make that addition too. You may want to check for contact like I did on mine. The Limited Pro in this short time shows a couple of hits and of course the beaver is really visible.
If you get the Sprinco you may want to contact them because the Corbon model is for full throttle nukes! The standard may fit the bill and just change to your spring level on the outside. At any rate it is 60 day money back plus lifetime on breakage. Don't like it, send it back!
