44 Magnum Prabellum Research(PBR) 240gr V-Supreme FMJ & Premium 240JHP
Started by The_Shadow, May 31 2013 09:06:35 PM MDT
Cartridge is from Ammo Manufacture: Prabellum Research (PBR) 240gr V-Supreme FMJ
Ballistics Information: 44 Magnum
Muzzle Velocity: 1455 fps
Muzzle Energy: 1127 ft. lbs
Brass Make/Headstamp: StarLine - Brass
Bullet Make/Weight/Construction/Info; Length 0.7110"/Dia. 0.4305":  240gr. FMJ
Actual weigh 239.8 grains  Cannelure Diameter 0.4125"
Meplat 0.2600"
C.O.A.L.: 1.5995"
Primer: Nickel color
Case: Diameter 0.4535" Crimp Diameter 0.4445" Length 1.2750"
Powder Description/Positive ID/Type/Charge Weight: H-110/W 296  22.0 grains
Tested from S&W Model 29 8 3/8" 1483 fps June 8th 2013
Case expanded to 0.4605", primer slightly flattened, case look good.
Cartridge is from Ammo Manufacture: Prabellum Research (PBR) 240gr Premium JHP
Muzzle Velocity: 1258 fps
Muzzle Energy: 843 ft. lbs
Bullet Make/Weight/Construction/Info; Length 0.7040"/Dia. 0.4305":Hornady  240gr. JHP
HP Inside Dia 0.1320"   HP Depth 0.0970" Mouth 0.2425"
C.O.A.L.: 1.5980"
Case: Diameter 0.4535" Crimp Diameter 0.4405" Length 1.2735"
Powder Description/Positive ID/Type/Charge Weight: H-110/W 296  21.6 grains
Tested from S&W Model 29 8 3/8" 1436 fps June 8th 2013
Case expanded to 0.4600", primer slightly flattened, case look good.
