Cleaning the XDm 3.8 compact 9?s striker channel
Started by Kenk, January 06 2023 10:10:33 AM MST
What method are you using to clean your  XDm striker channel? I do have some extra roll pins from Powder River, but it seems kinda silly to remove the pin unless there?s a real problem. As of now, I just give the striker channel a few blasts with Gun Scrubber, and then hit it with canned air
38-40
I have been spraying a little gun scrub then use a brush where I can. Then blow out with compressed air then repeat with CLP then blow that out as well. Working so far.
Thanks, I really like Birchwood Casey?s Gun Scrubber, but my last 3 cans have run out of propellant prematurely leaving me with a 1/3 to a half can that I can?t use. In all reality, I should call or email them, who knows, maybe they?ll send me a free can 😊 it?s expensive stuff as it is, but only being able to use a portion makes it all that more expensive
czgunner
Quote from: Kenk on January 06 2023 12:22:23 PM MST
Thanks, I really like Birchwood Casey?s Gun Scrubber, but my last 3 cans have run out of propellant prematurely leaving me with a 1/3 to a half can that I can?t use. In all reality, I should call or email them, who knows, maybe they?ll send me a free can [emoji4] it?s expensive stuff as it is, but only being able to use a portion makes it all that more expensive
Buy non-chlorinated brake parts cleaner.
Sent from my Pixel 3 using Tapatalk
#4
I?ve read many times of people using brake cleaner in place of standard gun solvents, but haven?t tried it, so no I?ll affects on plastic or polymer parts then?
czgunner
Quote from: Kenk on January 06 2023 03:14:51 PM MST
I've never heard of an issue when you use NON-CHLORINATED brake parts cleaner. When I was a mechanic, we used it all the time on plastics and never had a problem. Chlorinated will damage some plastics. Carb cleaner will damage some plastics.
Thanks, any particular brand you recommend? I?m assuming it?s substantially cheaper, or no
czgunner
Quote from: Kenk on January 06 2023 03:52:20 PM MST
Cheaper the better.
38-40
That?s unfortunate I have not experienced that with gun scrub. Hopefully I won?t have to. I have used brake cleaner as well but prefer not to as it seems to leave a film.
blaster
thanks for the brake cleaner idea. I learned the hard way about getting oil in the striker channel!
#12
Non chlorinated brake cleaner works fine for guns. A good friend of mine's father is a well known bench rest rifle maker. Some of his custom hunting guns go for $30,000-$40,000. He's used whatever is on sale at the auto parts store for years. Carb cleaner on barreled actions, non chlorinated brake cleaner on most everything else.
This will be a huge money saver, considering a large can of Gun Scrubber is around $15.00 -  $18.00
