G20 Mag Spring ?
Started by Alaska, November 28 2022 07:19:36 AM MST
Alaska
I have a Glock Gen 4 G20 what is a good magazine spring for enhanced reliability with Hot loads ?
#1
Never had any issues with hot loads on a G20/3... magazine spring always worked fine .
Remember that mags are a replaceable item and now and then they do wear out a bit.
Maybe you should more look into the main slide spring with hot loads.... stock is 17lbs (?) and I changed that out for hot loads with a 22lb.
this will slow all down a bit and may fix your issue.
Alaska
Already done that NDZ 22 pound kit with KKM barrel.
But thanks for the tip !
Quote from: Alaska on November 28 2022 11:13:21 AM MST
So this happens with all your mags ?
also does it happen with the stock barrel?
Alaska
I didn?t say anything happened !
I added the Wolff Additional power mag springs for increased reliability in the G20.
Thanks All !
