10mm OAL differences (if any) for pistol caliber carbine loads
Started by Kenk, January 05 2022 07:17:00 PM MST
Will be loading some 200gr GD / BE-86 loads tomorrow for my P220 Elite and High Point 1095TS carbine 10mm?s. Is it likely that both weapons would feed correctly with my standard 1.25 OAL
Thanks in advance!
The standard for 10mm is 1.2500" to 1.2600", however I have seen COL from 1.2400" out to 1.2700" depending on the magazines and bullet nose profiles.
DoubleA
Only one way to know for sure. Plunk them. I tend to always just run 1.255 and Ive never had an issue. But thats in a Glock.
Thanks, I plunk test everything so should elevate the issue for the most part
