The soap opera continues
Started by gadabout, March 09 2021 05:25:35 PM MST
gadabout
I was happy when I had a small pistol primer loading tube unstuck with a wire coat hanger. It has been stuck and plugged for a leased a year. It is special as it is loaded by a vibrating primer flipper type gizmo and I have been loading primers one at a time for a long time. Well of course I can't find the flipper anywhere, I did load the tube with 50 primers and the tube worked perfectly. It's better than it was and I will find the flipper thing but what a hassle.  Craig
gadabout
This is about 10 minutes later. I found the missing primer flipper right where it was supposed to be but covered up so I just kept missing it. I can fly now!!!  Craig :))
Lol, glad you were able to find it
gadabout
Well it does work but barely. It's a Franklin Arsenal plastic thing. The primer flipper has two outlets, one for small primers and one for large. The small outlet wasn't working so I used the large and with a small pistol tube it work OK. Possible it's dirty or when you put the vibrator, tube and fflipper together something jams up so I will work on that some more. It's always something!!!  Craig
