Long-load the M610
Started by sparkyv, December 20 2020 06:49:17 AM MST
sparkyv
I want to push the velocity higher in my M610, but I'm not ready to ream it out to a magnum just yet.  I've read where some have long-loaded the 10mm auto cartridge with some degree of success, but my searches for details  on this topic have been futile.  I would like some suggestions and thoughts on the matter as well as pitfalls. I recognize the possibility of "prairie dogging" projectiles to less opportunity to crimp less effectively, but would appreciate any feedback.
sparkyv
You might want to experiment using W296 / H-110 powder and actually apply a good crimp if you load long.  That could possible yield you some good velocities while keeping pressures decent!
I would suggest studying 41 mag and 357 mag data to find a load close for the bullet weight you want to use to get a slightly compressed load...
Good luck and post your results to include the COL, powder weights for velocity obtained.
sparkyv
sparkyv
CtYankee
Let me play Devil's Advocate.  the 10mm Magnum case is ΒΌ" longer than the 10mm Auto so you're not going to be able to set bullets out enough to equal its powder capacity. A good deal of the bullet's resistance to initial movement is from neck tension not crimp (expecially taper crimp). Unless you are using heavy bullets (200gr+), or you're seating bullets without expanding the cases you will have reduced neck tension. I tried seating a 200 gr GDHP to half its normal seating depth, I gained less than .02" of case capacity. I put a heavy taper crimp on it (dummy cartridges - no powder) and found that I could disassemble it in my impact puller much easier than those seated to standard depth: however, that doesn't mean that the bullets didn't have enough resistance. I'm not sure that the 10mm Auto case will allow enough H110 (even w/ bullets seated long) to show any improvement. If a 610 can headspace off the moonclips you might be able to use a roll crimp - you can buy a cannelure tool from CH4D for $130.  You can increase the velocity potentialof the 10mm Auto, but I don't think that you'll hit 10mm Magnum velocity unless you ream it to 10mm Magnum. It depends on what you want. I use my GP100 for ICORE competition and load for a power factor of 130-125. I know I can hit 1150 fps with a 200 gr bullets and maybe get to 1200 fps, that seems adaquate for me.
sparkyv
#4
Thanks for the contraperspective; I appreciate all POV.  I'm a natural tinkerer and am just in the investigative phase, but if I gained less than .02" of case capacity, H110 efforts may be in vain.  If there's not enough neck tension, then I'll load up only one round at a time.  Totally impractical, but good enough to pass over the chrony. I didn't expect to reach 10mm Mag performance,  just want to wring out a bit more.
sparkyv
Bimmer
I was hesitant to ream my cylinder for 10mm Mag, but it was actually quite easy...
If you really want more oomph, then go for it.
Caveat:  I wasn't able to replicate the velocities that Taffin reported (not even close).
I lost interest in going further when I started splitting cases with 200gr Gold Dots at ?1,200fps.
Some of that may be due to my sloppy DIY reaming job, but some of that is just the limits of a 6-1/2" barrel.  (IIRC, Taffin was testing using an 8" autoloader.)
sparkyv
I've put this project on hold as my new M617 is inbound and am looking forward to putting her through its paces.
sparkyv
FN in MT237
   OR..... Just get a .41 mag?  A lot easier.
Mike D
Quote from: sparkyv on December 20 2020 06:49:17 AM MST
You can always buy an extra cylinder and ream it out.
sparkyv
I thought the extra cylinder would require hand-fitting.  I'm pretty sure the hand has to be worked match the cylinder, so swapping between the two calibers is not a trivial task.
sparkyv
Mike D
Quote from: sparkyv on October 09 2021 05:42:20 PM MDT
I thought that applied to single actions only.
sparkyv
Have you successfully obtained a second cylinder for your M610 and it fit without modification, MikeD?
sparkyv
Mike D
Quote from: sparkyv on October 22 2021 06:22:07 AM MDT
I have not. Since I?ve not had the cylinder reamed yet, I?ve not done anything with it.
Sent from my iPad using Tapatalk Pro
